Home > Technical (L322) > Limp mode after first drive in car having done all the work.
Tiprat
Good evening everyone, so as per title, I've finally finished all the work to get the car road worthy. Insured and taxed it, took it out on its first drive and after it had done 30mins of urban driving, we took it onto the duel carriage way, under normal driving up to 70mph no issues, faultless, smooth, refined, everything my partner had hoped for. She then decided to overtake a hgv and "put her foot down". Censored
No noises, no obvious black smoke, nothing, just a bong on the dashboard message and up pops " Engine system fault" Big Cry and into limp mode, able to rev the engine, engine sounded fine, just no power. Pulled off asap, onto a side road, turned ignition off and back on, back to normal, power, smooth delivery, no smoke, everything sounds normal.
Got home ran my diagnostics, and under power train I got this picture.
Has anyone got any ideas for me to start looking for....
I cleared all the dtc's and it came back clear, no fault codes.
Post #611323 1st Nov 2021 6:50pm
JayGee
It would help to know the year and engine etc Wink 2012 TDV8 Vogue (L322)
Post #611332 1st Nov 2021 7:29pm
The answer is here.....probably Whistle
Post #611333 1st Nov 2021 7:46pm
Tiprat
Jaygee, sorry I thought I'd put on my profile, the model is a 2007 3.6tdv8 Vogue SE. 160k good service history mostly via dealerships, mid covid I believe it had both turbos and egr valves replace.
Alistair, I've looked at your link, it brings up a full page of headings, could you possibly narrow it down a little, I so want this RR to be everything she wanted it to be.
Post #611334 1st Nov 2021 7:58pm
JayGee
On a 3.6 the first thing to check is any splits in the IC top hoses. 2012 TDV8 Vogue (L322)
Post #611336 1st Nov 2021 8:13pm
Sorry - I just searched on the error message Smile
Given the fault says MAP, maybe - https://www.fullfatrr.com/forum/topic48765.html
As above though - 3.6 TDV8 is often one of the hoses and that's a quick & cheap fix
Post #611338 1st Nov 2021 8:32pm
JayGee
MAP sensors are cheap. 2012 TDV8 Vogue (L322)
Post #611342 1st Nov 2021 9:06pm
