![]() | Home > Technical (L322) > Time Delay --is it Normal |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
The camera turns off when moving fwd over 11mph.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995
Yes that’s normal.
| Old Barty Member Since: 05 Sep 2021 Location: Suffolk Posts: 23
Well Thank you both, Gentlemen --- That's the first bit of Good News i have had, Let's hope it's onward and upwards
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
That's a sticking caliper old boy |
I’d agree with the above diagnosis. They do suffer from this. Wheel bearings do it too, but you might hear that or be able to feel play in the road wheel.
Thanks Guys, It's a strange one -- It's happened twice now at different times -- Today when it cooled down, I drove it under the carport and took the wheel off and it was as free as a bird. The 2 slider pins are both free and I could push the piston back fairly easily and the pads are nice and free However when I pressed the brake pedal again and released it, the disc was as tight as |
