![]() | Home > Maintenance & Mods (L322) > Rear Calliper Piston Stuck |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I'll do a separate write up on my calliper overhaul but you can see I had to resort to extreme measures to get my piston out.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
I'm a big fan of 'make do and mend', but given that the rear callipers are pretty innexpensive, I think this may be taking the mantra to extremes! The older I get, the more I realise that people confuse wrinkles for wisdom |
Pattern parts are cheap. TRW original ones aren't, they're about £200 each.
£200!!!! Is that from a main dealer?
They're £200ish from LR Direct. Christian.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8748 ![]() ![]() ![]() |
Here you go... |
Paint hardening overnight and reassembly tomorrow.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
That piston looks nasty! |
