![]() | Home > Technical (L322) > Steering lock / ignition lock woes ... level 2 |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Had the steering column lock repaired a couple months ago. Experienced what I thought was a hiccup with it (key not turning) so after restoring normal function with the...rubber mallet I installed the goldcar key emulator I had procured just in case. Local indy has been super busy since summer so we haven't really had the chance to take another look at the lock...
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
I had similar on the Td6. Needed to change the ignition switch, On your MY the position of the switch makes it a magnet for carp. John
Thanks John,
Update.
Well,
Okay, to wrap this up:
