![]() | Home > Maintenance & Mods (L405) > Deployable Tow Bar |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
Is there any maintenance that can be done on this? Mine played up this morning and it took about a dozen resets before I got it deployed - I think it was due to the cold. Geoff |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
How's your battery, Geoff? If you have an IID, check for battery related codes? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
try the deployment when at slightly higher revs and see if that makes a difference.. ... - .- -.
I never actually try to deploy with the engine running at all - something to try |
| IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 301
On mine, you can't deploy the towbar with the engine running
this towbar diagnostic pdf from the WM suggests that the engine can be running?
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Read the very last box of the diagnostics |
you read all that pdf?
I kind of skimmed it.
I would have to check but I don’t think mine will deploy with the engine running Stan… 👍 |
Thanks all, I haven't tried deploying with the engine running so I can't comment on whether it is or isn't possible BUT according to my IDTool the battery voltage is only 12.6v without the engine running rising to 14.4v at tickover. The document suggests you need 14v at least for the tow bar to deploy, so even though the car starts fine I bet on a cold morning it's even lower than 12.6v. Todays readings were taken on a Tesco car park while I waited for SWMBO to do a bit of shopping. I plan on simply leaving the tow bar alone (its deployed now) until the battery gives up properly. Geoff |
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123
I seem to remember someone posting a link to a video of a failed unit being striped and rebuilt with a £2 micro switch that was sticky. letters not necessarily in the right order |
