Home > Technical (L322) > Fault Codes - sanity check
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Got my IID Tool yesterday and have scanned and cleared a few times. The errors below remain.
I know my compressor is goosed and that's getting replaced by the garage on the 8th so I think the suspension, abs, cruise fault codes relate to that as the suspension doesn't work and has a fault (she doesn't sink though). The audio fault codes - I've searched on here and apparently most RR's of my age (2010-2012) have the same and it's a 'red herring'. The p040D has been discussed before and most people ignore it.
There were others relating to drivers seat climate control however that all works correctly. My initial suspicion was perhaps the battery - while it's running, IID does indicate 14.4-14.7v and when sitting with the ignition off it's at 12.4.. dropping to 12v steady.
Just wondered if folk can confirm what I've said above so I don't need to worry or dig deeper for anything.
Model L322 - Range Rover 2011
Vehicle scanned on 18 Nov 2021 11:53:26
IIDControl 3.0.0 Build 84 Android - IIDTool BT V4.0 B2742
AAM-Audio Amplifier
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
( on 18-11-2021 11:48:48 at 220231 km )
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
ABS-Brake Module
U0421-68 (2B) Invalid data received from ride level control module - Algorithm based failure - event information
( on 18-11-2021 11:48:41 at 220231 km )
CCM-Cruise Control
U0421-81 (2E) Invalid data received from ride level control module - Bus signal/message failure - invalid serial data received
( on 18-11-2021 11:50:11 at 220231 km )
PCM-Engine TDV8 4.4L
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
( on 18-11-2021 11:47:42 at 220232 km )
RLM-Suspension
C1A13-64 (2E) Pressure does not decrease when venting gallery - Algorithm based failure - signal plausibility failure
( on 18-11-2021 11:47:43 at 220231 km )
C1A36-01 (AF) Exhaust valve - General failure information - general electrical failure
( on 18-11-2021 11:47:42 at 220231 km ) 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #613026 18th Nov 2021 1:02pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Pretty normal. The only thing I would look at is the gallery venting issue.
It probably needs the compressor filter to be cleaned. I didn;t drill a hole in mine like some resort to, I just blew it out with an airline and soaked in soapy water for a while and then blew it out again.
Tested it with the "put it in your mouth and blow" technique and it was really free-flowing. Job sorted. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #613030 18th Nov 2021 2:11pm
MartinD
I'll do that once the compressor is replaced, thank you.
I don't have an air compressor at home and don't want to mess with it too much as I'll then be unable to raise it. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #613037 18th Nov 2021 2:44pm
Caesium
You can unbolt the filter without disabling anything. It's a 17mm spanner only. Christian.
Current Cars
2019 BMW X4
or
Post #613038 18th Nov 2021 2:48pm
DrRob
A few of us replied on your other thread about some of the codes e.g. P040D Thumbs Up
Not going to repeat Whistle Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #613039 18th Nov 2021 2:48pm
MartinD
Yup - that's why I specifically mentioned that code and that I'm not going to do anything about it at the moment Smile 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #613042 18th Nov 2021 3:04pm
