Home > Maintenance & Mods (L405) > RR L405 2014. “Low Battery start Engine” warning |
Friendee Member Since: 06 Nov 2021 Location: Clwyd Posts: 19 |
New batteries didn’t fix touch screen issue,
28th Nov 2021 1:06pm |
Were they replaced by JLR? If not, was the ecu updated to know it has had a battery replacement? |
29th Nov 2021 1:24am |
Replaced by Landry independent Landranger of Deeside, but will check later.🙈 |
29th Nov 2021 12:03pm |
Ok, yes the car needs to be told via diagnostics that the batteries have been replaced… Or the low battery message may stay on the screen etc etc |
29th Nov 2021 12:07pm |
Landranger remapped the car on battery replacement. No ‘battery low’ warnings at present. They showed me about two weeks ago on their diagnostic equipment the three crosses in the boxes relating to Audio, sat nav and phone, which were all working when I bought the car in August this year (my first Landy) They consulted a specialist and recommended checking the two high level located
29th Nov 2021 3:12pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Getting similar on My 14 AutoBio 5L SC has the smaller motorcycle style battery. I checked the voltage when off and it read 13v when off and 14 with engine running. It was hooked up to the leads but my start stop is somehow not working (I don’t mind having no start/stop…button lights fine but seems Prev owner disabled it somehow). But I get “low battery warning on the dash”. I just changed my main Bart like 3 months ago (did not have it programmed) and it reads 12.x volts when off and 13 with engine running. Is this normal? Why am I getting the battery errors…bc I didn’t get the new main battery registered? Or is the AUX battery malfunctioning with the read-outs it’s giving me? 2014 FF Autobiography 5.0 SC
1st Dec 2021 4:09am |
2014 L405 RR Vogue
8th Dec 2021 10:30pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 442 |
Hi Horse86, you need to get your main battery programmed to enable the electrical systems to function correctly. This would include the auto stop start. The function of the auxiliary battery is to keep the voltage stable while the main battery starts the engine in the auto stop start cycle. I changed my main battery and the auto stop start did not work until I programmed it with a diagnostic tool.
8th Dec 2021 11:26pm |
Thanks diesel…
20th Dec 2021 7:46pm |
