![]() | Home > Technical (L322) > Electric Windows Reset |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3347 ![]() ![]() ![]() |
So you don't cycle the actual window up and down just the switch repeatedly to the up position? 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I'm sure that's what I did too on my passenger side recently. It stopped going up so I just repeated holding the switch up a few times with the window still shut if that makes sense. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262 ![]() ![]() ![]() |
That’s what I did for all windows (and sunroof) after reconnecting battery. You will hear a faint click after a second or two holding the switch in the up position, presumably a relay, solenoid or whatever resetting. 2011MY 4.4TDV8 Autobiography Baltic Blue
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Use IID tool and it will do all the windows in one go. Christian.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Great tip. I applied this yesterday to my car where two windows on the drivers side lost it. All good again. |
Never thought of that ![]() Where is it in the menu please? ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
