Home > Technical (L322) > Electronic Handbrake
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
When I start the car I get a parking brake warning and a yellow triangle for a fraction of a second before it starts.
The warning then disappears. Is this a warning that something is going to fail, is it common for this to happen?
Any thoughts would be useful Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #615261 8th Dec 2021 9:56am
leave the brake off [or on] and see if the warning comes up again .. ... - .- -.
Post #615263 8th Dec 2021 10:11am
mjdronfield
I’ve never had that. Not sure if there is something underneath you can lubricate, though I would have thought you’d got any error when applying it, but I’m no expert on the EPB.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #615264 8th Dec 2021 10:13am
Caesium
It doesn't come up if the handbrake isn't applied...(?) Christian.
Current Cars
2019 BMW X4
or
Post #615265 8th Dec 2021 10:15am
JayGee
Have you got a GAP IID tool to check any codes?
Mine flashes occasionally and the GAP fault codes continually reports loss of communication with the handbrake ecu but I just assume this is spurious or marginal voltage when left overnight.
Don't get any warning symbol though. 2012 TDV8 Vogue (L322)
Post #615280 8th Dec 2021 12:06pm
Caesium
Not seen any fault codes, the previous owner replaced the rear discs but I'm not sure if he adjusted the shoes correctly. Reason for this is that he clearly didn't notice the seized calliper so doubt was all that competent.
I think I'll get the rear wheels off at some point and check the shoes and EPB mech when the weather breaks a bit. Christian.
Current Cars
2019 BMW X4
or
Post #615285 8th Dec 2021 12:27pm
