Home > Technical (L322) > Quite urgent, stuck on French motorway.
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
2006 4.2 supercharged.
A few weeks ago, i was getting P2601 coolant pump circuit.
Having read all about the wiring issue, I bought a new pump and fitted it, checked the wiring was correct when putting it back and all seemed well.
But today towing i got the same warning!
Any clues what it could be now?
Thanks!
Post #615286 8th Dec 2021 12:40pm
dingg1
https://www.obd-codes.com/p2601
Some trouble shooting guide here
Post #615288 8th Dec 2021 12:53pm
a quick google comes up with this..hope it helps,
P2601 is typically set because of electrical (CP-A circuit) issues but can be caused by mechanical issues, such as a mechanically stuck impeller on the electrically driven coolant pump. Both electrical and mechanical issues cannot be overlooked in the troubleshooting stage, especially when dealing with an intermittent problem.
Post #615293 8th Dec 2021 1:15pm
philip1972
Thanks.
Water pump is new and gauge has never moved a mm, so I am confident that if the engine waterpump was knackered, it would have started to heat up....especially up and 10km steep motorway hill with the horsebox on the back.
Post #615303 8th Dec 2021 1:50pm
