![]() | Home > Technical (L322) > Bloody air suspension!!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
"as I have always had intermittent Suspension Fault and Vehicle lifting slowly fault warnings since buying the RR just over a year ago."
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Yup pretty amazing it’s been going well for a year. I do think the bum gauge ometer is differently calibrated for different people as I’m very sensitive to these things. I notice it immediately in mine, and even in my daughters evoque I noticed it when we were buying it and the owner said it rides fine.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6834 ![]() ![]() ![]() |
I had the “filling too slow” message for ages and replaced the compressor twice but finally tracked it down to a hole in the reservoir tank, which was replaced and all is well. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
Probably had a leak somewhere for a while and your compressor is now past its best and finally thrown its hand in, try find the leak, try running the compressor and checking the output. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2749 ![]() ![]() |
The first fault suggests that the brass exhaust filter is blocked, which is easily fixed with a small drill bit. The other faults suggest that the compressor has problems of which there could be several causes. |
GrunterNI Member Since: 30 Oct 2020 Location: Co Down Posts: 48 ![]() ![]() ![]() |
Thanks for all your replies guys, they’re really appreciated |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
If you do go down the replacement route only fit the AMK unit, I fitted a cheap Dunlop and it only lasted 16 months |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3347 ![]() ![]() ![]() |
Once inflated the suspension should not deflate even if you disconnect the compressor. I would suggest the issues is with a leaking suspension bag or pipe or valve block. 2012 TDV8 Vogue (L322) |
Thanks for that info JayGee because my simple mind was thinking that a leak at the compressor would also cause the suspension to drop. The previous owner replaced the reservoir below the drivers side so I suspect that there must have been a problem then.
I'm no expert on this but .......as you can change the compressor and the system doesn't deflate there are valves as well. These regulate normal height changes and the pump keeps the reservoir full. The pump itself can't generate the large volume of air necessary for say going from access to offroad quickly and the reservoir does this. Unfortunately there are numerous places for the system to leak. The GAP IID tool will help identifying a faulty compressor or valve but not a leak. Your ear and some plumbers gas leak fluid/spray will help. Plenty of info on this forum via the search function 2012 TDV8 Vogue (L322) |
As I mentioned above, mine turned out to be the reservoir. I also changed the valve block on the O/S rear, which ultimately wasn’t my problem.
Thanks alanm_3, once I get the compressor rebuilt and the sensors changed that'll be the route I'll be going by the looks of it Current collection :
It would be a quick check for the reservoir. It runs from front to back under the N/S cill, a liberal spray of the soapy water will produce lots of bubbles if it’s leaking, much quicker that changing valve blocks etc.
It was replaced about 6 or 7 months before I bought it and still looks like new so its not the reservoir. Soapy water, patience and several cups of tea it's going to have to be Current collection :
