Home > Technical (L322) > Window anti trap issue but only when it's cold
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Hi All,
I have done a few searches but not really come up with an answer.
Basically, whenever it is cold (or even just cool), my drivers window will not auto close. It gets almost to the top and then bounces back down again, stopping a couple of inches before the fully open position. I understand that is the expected behaviour when it thinks the window is blocked. It sometimes does the same thing when holding the button too.
It does it every winter and behaves in the summer.
I've seen suggestions that it could be a faulty switch, but is the anti trap function really anything to do with the switch itself?
If so, can the individual switch be replaced or does the whole pack need replacing on the drivers door?
Or is it likely to be something else? I've tried various resets - the glass doesn't seem to be physically sticking in its guides. Not sure where else to look.
Anyone got any ideas? 2010 4.4 TDV8 Vogue SE
Post #616347 14th Dec 2021 4:00pm
diesel Dave
You could try some silicone spray down the window guides on both sides, (spray on dash polish does the job). If you do have a fault it wont fix it but will make it easier for the motor to drive the window up and down.
I often Use it on the defenders with electric windows that are sluggish, its amazing how much better they work.
Post #616569 16th Dec 2021 8:17am
Sandyt
Gummi Pflege is the answer its about a fiver
Post #616573 16th Dec 2021 9:14am
kooky_guy
I've got done of that somewhere. Will give it a try.
The window doesn't feel slow or tight though - it's literally behaving as though it's blocked just before it gets to the top. 2010 4.4 TDV8 Vogue SE
Post #616580 16th Dec 2021 10:18am
kevinp
Mine does that when I try to close the window at 70mph. I have to slow down to 60mph before it will close. Obviously my window is being 'sucked out' with the speed of the car so I wonder if your window channels have swelled a bit, pinching the window. Can you get a wide blade screwdriver and make sure there aren't any tight spots in the window channel?
Post #616592 16th Dec 2021 11:06am
kooky_guy
Good idea. I'll give it a try. 2010 4.4 TDV8 Vogue SE
Post #616600 16th Dec 2021 11:33am
Slow progress
I have the same issue on my 2018 Mercedes, it seems to get damp in the inside, and only starts working when it drys out
Post #616645 16th Dec 2021 4:38pm
Silicone spray down the channels for sure... Thumbs Up
Post #616686 17th Dec 2021 12:54am
kooky_guy
Just a quick follow up for this, the silicone spray appears to have totally fixed this. I was sure it was a mechanical issue but clearly not!
Thanks all! 2010 4.4 TDV8 Vogue SE
Post #624209 20th Feb 2022 1:07am
mjdronfield
Mine still does this, only when very cold. Think the window rubber is less compliant, I put light pressure on top corner of the glass when it’s going in the last nit. Fine for ages then. Just that you have to stop driving to do it 🤣.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #624238 20th Feb 2022 1:41pm
