Home > Maintenance & Mods (L405) > Batteries and Stop/Start
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
When I bought it, my FF showed the low battery warning.
That’s since gone. But even a 330 mile round trip hasn’t got the start / stop working.
My guess is the main battery needs replacing and all will work again.
Am I right? What do I put here then?
Post #616408 14th Dec 2021 11:37pm
millerj90
I thought it was the auxiliary battery thar was responsible for Stop/Start.
Willing to be corrected
Post #616412 15th Dec 2021 12:32am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
My car has just had its 6th birthday, the stop start has not worked for a few years and I decided it was time for a bit of pro-active work so had both batteries replaced at the service. Stop start working again, so now I start the car and turn off the stop start straight away. letters not necessarily in the right order
Post #616418 15th Dec 2021 7:23am
Vogue
It’s the small auxiliary battery behind the rear right boot panel that needs replacing - or it’s been disconnected 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #616419 15th Dec 2021 7:35am
GAC23
Thank you all.
Had both batteries tested last week.
The aux battery showed as "good". The main one "good but low".
Logic suggests if it can be tested, the aux battery is connected. However, this is a FF so logic may not apply Laughing
I'm actually wondering if I have stop / start ...
... every other car I've driven with it has a button to switch stop / start off. Mine doesn't.
Is it possible I don't have it and the aux battery is for something else? What do I put here then?
Post #616422 15th Dec 2021 9:04am
Entirely possible.
Mine doesn't have stop/start but does have dual batteries.
Post #616426 15th Dec 2021 9:22am
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
I’ve got a 2015 SDV8 and pretty sure mine hasn’t got stop/start
Post #616427 15th Dec 2021 9:25am
JCW
Came in on MY16 models through 2015 (generally 65 plate onwards) will have a stop/start off button on centre tunnel if it’s fitted Thumbs Up
Post #616429 15th Dec 2021 9:45am
TJH1985
Both batteries on my 15 plate tested as good, but stop start worked once every now and again. Replaced both and it works all the time now Mr. Green Not sure if thats a good or bad thing... Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #616441 15th Dec 2021 10:17am
GAC23
Mine was first registered 1.3.15 and I've not seen a stop / start button - will have to double check now.
If it doesn't have it, what's the aux battery for? What do I put here then?
Post #616443 15th Dec 2021 10:18am
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
Stop/Start was a£460 option on MY2015 and not a standard fit on any model including the AB and SVAB 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #616444 15th Dec 2021 10:18am
GAC23
So all cars had the aux battery. But you only got stop / start - and the button for it - by paying the £460 extra? What do I put here then?
Post #616446 15th Dec 2021 10:22am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Yes, but think of all of the money you save when stuck in traffic.
Post #616448 15th Dec 2021 10:38am
JCW
Pretty sure it was standard on all MY16 models onwards, happy to be corrected.
Post #616449 15th Dec 2021 10:45am
The second battery is there because why not ? Very Happy
It provides extra power for all the other electronic bits & pieces and an extra bit of starting boost if required. Other than cost to replace & a bit of weight, no down side.....
Post #616451 15th Dec 2021 10:52am
