Home > Technical (L322) > Anyone with a AJV8 2006
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I'm after a little help from anyone who has a 2006 AJ engine FFRR . You may have seen my previous posts regarding my heating issues. It looks like I have another issue & has me totally confused with the coolant hoses.
Trying to replace the hose from the auxiliary pump to the engine outlet, but it appears that this pipe doesn't exist?. Looked at all the sites, etc & I'm unable to find one.
The hose is one piece with only a snap connector on each end. It runs around the rear bulkhead with the other two hoses down to the aux pump.
What I need to confirm with another owner is that they have the same pipe, using the same route. (This is the petrol engine without an FBH).
Thanks in advance.
Post #616540 15th Dec 2021 9:25pm
Jimmy123
Can you provide a picture of yours and i will have a look tomorrow
Post #616846 18th Dec 2021 8:59pm
Highroller
Ok, Here are pictures with the pollen filter housing removed.
What I need to clarify is the following.
1. that the hose on the left (Highlighted in red) goes from the metal pipe on the left directly to the far left bulkhead connection.
2. the Right hand hose, goes from the Right hand pipe under the other pipes directly to the Auxiliary pump without any other connections.
Thanks.
Post #616888 19th Dec 2021 12:05pm
Jimmy123
Sorry for not getting back, your pictures look the same as my lay out !
Post #619216 8th Jan 2022 5:13pm
Highroller
No problem & many thanks for coming back to me, as this saved me from swapping the hoses around.
Unfortunately in that case, I now have No Idea where to go next Shocked .
Hopefully it will be a mild winter Laughing
Post #619218 8th Jan 2022 6:12pm
