Home > Technical (L322) > Rim sizes
spanner
Rim sizes
Hello to all
I have a question i want to get my wheels powder coated they are 22s but i need to use the rangie for work so i have aquired a couple of 19s my issue is can i run 22s on the rear and 19s on the front for a few days while the 22s are coated
Thanks
Post #67017 5th Jun 2011 9:29am
Apart from looking like a tractor it's the total radius with tyre that counts here not the actual rime size. 2008 MY Supercharged
Post #67019 5th Jun 2011 9:50am
you could spanner ...
the difference is 5mm on overall diameter so it dont sound to bad..
285/35/22 has an overall diameter of 758mm and,
255/55/19 has an overall diameter of 763mm.............
obviously you shouldnt rag the car with these on..
Post #67022 5th Jun 2011 10:21am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
A few years ago I had to get one of my AMG'S refinished on my Merc S class and was told that as long as the difference is not greater than 10% you should be OK anything greater means you run the risk of transmission wind-up and could damage tranfer box or gearbox/transmission parts Shocked
Post #67063 5th Jun 2011 3:42pm
its actually recommended to have no more than 2.5% difference ,plus or minus...
Post #67073 5th Jun 2011 4:11pm
I've never measured my rim Laughing .
Post #67277 6th Jun 2011 6:47pm
