![]() | Home > Maintenance & Mods (L405) > L405 underseal |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 670 ![]() ![]() ![]() |
I use lanoguard on mine, there are a few shields I’d love to remove sandblast and galv one day. Maybe something to pick up from a scrap and do.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Most of the steel stuff is bracketry, which I wouldn’t be too concerned with protecting. Used to do it to stop floor panels etc rotting or chassis members, but with the main structure of the 405 being aluminium I’m personally not worried if occasionally a crossmember shows a bit of rust. If at some point it get too bad then it’s an unbolt and bolt on a new bit….. much less messy and hassle than trying to treat the whole of the underside of a car which won’t rust….. There is nothing that can't be fixed with a hammer😜😜
The problem is when the rust creeps between the bracket and the aluminium it’s bolted to, aluminium is great until it starts to corrode and once the paint is broken and you have two dissimilar metals touching it only takes a bit of water or salt to really accelerate the process.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
I’ve waxoyled mine, concentrating on any metal work including tank saddles but mainly the ARC pipes, these are only on the SDV8 on the L405 but can be expensive to change as are a PIA to do due to the route they take. I removed the plastic panel under the sill, drivers side then gave it all a good coating. The brake pipes also corrode on the L405 so is worth a coating to save an MOT fail as they get older. |
cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 70 ![]() ![]() ![]() |
Thank you all. I will get it on the ramps and get it sorted. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1866 ![]() ![]() |
This. We've already seen a few worrying looking cars in...
Oh the joys of living in Scotlandshire... |
![]() ![]() How do you even begin to repair that? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
