![]() | Home > Technical (L322) > L322 Headlight Upgrade Options |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 777 ![]() ![]() |
deleted |
Have you checked that there’s no problem with your lights?
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
Lights are all fine and still have the original units in from what I can see. Maybe I’m spoilt as my BMW 640d is fitted with LED lights that have shutter technology and are brilliant. The RR aren’t very good in comparison so looking to upgrade them if I can relatively cheaply if I can…. |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
The LED's have probably spoilt you.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I'm with the others, I suspect something is not right...I came from a Mercedes AMG with Intelligent Light System (all singing dancing LEDs painting dark boxes on other cars and all sorts), my wife still has adaptive led by BMW on her M2 Competition.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I would agree with others here… you are either a) spoilt with the awesome bmw lights, or b) have an issue which affects their performance.
They do fade over time, so if the car has had a lot of driving in the dark that could be it. As you say bad glass can also cause degradation, I repolished my headlights to have them nice and clear again. |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I have updated the bulbs in my 2011 with new HID OSRAM lamps and they are still not as good as modern LEDS.
Christian
Neither were projector based headlights. Even with a bulb upgrade these will never look like LED or Laser headlights. But it’s a psychological thing as well as many people see white light and think it’s brighter and provides better vision. It actually really isn’t. |
Mark, check the link in my signature, I did a write up on the headlight bulb replacement on my project page.
Or better put, it doesn’t have to be.
Cheers Christian. I’ll certainly look into what you did and suspect it’ll be the way I go. Thanks again Regards Mark |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I can't fault my MY06 lights. I still marvel at their performance over and above all my previous vehicles and plenty of hire vehicles (including various BMW and Mercedes). Previous cars:
