![]() | Home > Technical (L405) > New D300 - DPF thoughts? |
| Hoyboy Member Since: 21 Oct 2021 Location: London Posts: 79
It’s done 11,000 miles since the last service.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
40 miles is more than adequate. Oil changes every 2 years is not. Personally I’d have it done every 6 months regardless. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
just a theory based on my experience with the 4.4TDV8. I had poor regen and high oil dilution. my thermostat housing was damaged and the engine was running too cool to regen properly. New thermostat cured all. have a look at the number of attempted regens and the Thermostat (housing and gubbins). get them to test the internal running temp of the engine. If it is running cool (these do anyhow) then it may not be able to complete a full cycle, but pumps diesel into the engine, thus adding to the dilution. Just a theory mind. |
| All times are GMT |
