Home > Maintenance & Mods (L322) > Rear upper suspension arm pin or bush
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Right, after a long think, and occasionally falling out of love with my aging old TD6, I’ve decided to keep her and get all the niggling little bits done to keep her on the road. Only do about 1-2k miles a year in it, but it’s time to do everything that’s needed. Hence the load of posts I’ll be making over the coming weeks/months.
First off, I’ll be pulling the handbrake shoes and fixings out to replace, while I’m at it I’ll get this MOT advisory done.
* Offside Rear Upper Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Do I buy the whole assembly? And can someone please post a link to an image of the part, or better still a part number? 2003 TD6
Post #620023 15th Jan 2022 10:43am
rjff
If you go to the Wiki and look in the third down Microcat you will find the diagrams you need.
The links open when followed to give a part number and photo. Search the part number in a browser and it sholud come up.
If you have trouble come back and I'll see if I can do a step by step, but it's fairly easy to follow. Cheers
Richard
Gap IIDBT
Post #620027 15th Jan 2022 11:09am
This
https://www.fullfatrr.com/forum/viewtopic....066a64f102
will either encourage you, or put you off Very Happy .
Post #620031 15th Jan 2022 11:35am
