Home > Technical (L322) > Air suspension schematic 2012
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hi
I have an air leak on my front Suspension somewhere, it dropping about 3-4cm overnight.
Can anyone post a schematic of the components?
It’s going into a local garage tomorrow for them to have a look at, can’t do it myself, as I’ve been in agony with my back for 2 months.
Just would be handy to give them details of where to look for leaks.
If one side was leaking, would it drag the other side down due to self levelling?
Cheers,
steve
Post #620613 19th Jan 2022 9:14pm
have you looked in the WM Steve? ... - .- -.
Post #620614 19th Jan 2022 9:29pm
SFM
Hi Stan
For some reason, my iPad will not download the wm
Post #620617 19th Jan 2022 10:05pm
SFM
Picked the car up from the garage tonight, they had a good look at it today, apparently passenger side airbag has a small split in it. Now looking at about €1200 to replace both front units.
Question is….if one side is leaking, will it drag the other side down, due to trying to level up?
Post #620740 20th Jan 2022 11:47pm
GraemeS
Australia
The vehicle will slowly level downwards but a leaking 1 side will put more weight on the other side making it lower anyway.
Post #620745 21st Jan 2022 2:42am
JayGee
After shut down it periodically wakes up to level itself so yes if one corner is down it will balance out across that axle. No need to do both sides and also no need to replace the whole strut as the airbag on it's own can be replaced. 2012 TDV8 Vogue (L322)
Post #620751 21st Jan 2022 10:33am
