Home > Technical (L322) > Pics added! IID tool arrived....here you go!! Code heaven
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Couple of codes relating to my suspension issues.
C1A36-01 Exhaust valve -general electrical failure
C1A07-62 Cross articulation-Algorithm based failure-signal compare failure
U0132-87 (0Cool Lost communication with ride level control module - Bus signal/message failure - missing a message
Before I start looking at everything, any hints? Is 1 issue causing all the rest etc?
Cheers all
Post #620779 21st Jan 2022 2:44pm
Do a reset and wait a few days. Got - 2017 SDV8 Autobiography in Loire Blue
Post #620784 21st Jan 2022 3:12pm
what Alan has suggested....do a fault clear and wait a week or so and then check again....those faults you have listed could be historical.. ... - .- -.
Post #620785 21st Jan 2022 3:23pm
Baltic Blue
I usually take a screenshot for future reference before clearing any fault displayed.
Post #620786 21st Jan 2022 3:48pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
You can email the fault list from the IID tool 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #620789 21st Jan 2022 3:55pm
JayGee
I call them 'hysterical' faults.....
The GAP IID tool is great but it can make you loose a lot of sleep if you are not careful. 2012 TDV8 Vogue (L322)
Post #620790 21st Jan 2022 3:55pm
Jayk69
U Codes are normally Ghost codes triggered by something else in your case the cross articulation.
maybe the self leveling had a fit or battery had a big hit on a start stop cycle. so clear and see what returns. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #620795 21st Jan 2022 4:19pm
philip1972
Photo of the calibration.
Could the difference be the issue?
Post #620797 21st Jan 2022 4:21pm
Jayk69
was that on a flat surface?
i would say they are out and you need to re-set there are some good videos on how to do this using old center caps Thumbs Up
or take it to a dealer and get them to do it 2012 Vogue 4.4 TDV8 - Current
Post #620799 21st Jan 2022 4:25pm
JayGee
Worth doing a calibration - very easy with the self guided mode on the tool. 2012 TDV8 Vogue (L322)
Post #620801 21st Jan 2022 4:29pm
philip1972
The above pic was the calibration setting (I think!)
the below image is the current height in standard mode.
Post #620817 21st Jan 2022 5:17pm
Jayk69
they all look off to me if that was taken on a flat level surface. i would defo get them re-done 2012 Vogue 4.4 TDV8 - Current
Post #621213 24th Jan 2022 12:51pm
philip1972
I have been trying to get them changed, but even though the new settings upload, after a drive they seem to revert back to what they were before?
Post #621219 24th Jan 2022 1:37pm
