Home > Technical (L322) > Water in spare wheel well
tpeat12
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Afternoon folks.
I'm currently working my way through the minor niggles with my recently acquired 5.0 S/C.
I've noticed that there is water in the rear wheel well and some unknown crystalline deposits forming on the underside of the boot floor. I had wondered whether it might be washer fluid and the crystalline substance is the anti-freeze chemical. I've also noticed that when I press the rear washer, I get a dribble of water running down the nearside of the window (on the outside). However, I'm sure that when I first picked up the car, the washer spray projected from the wiper arm as it moved over the window, which might mean that I have a partially blocked hose or nozzle. Could someone confirm how the screen wash should project onto the rear screen?
I've also noticed an unused connector in the spare wheel well with a little corrosion on some of the pins (see below). Does anyone know what this plug serves?
Cheers,
Tom
Post #621366 25th Jan 2022 5:21pm
kevinp
I think your unused connector is for the tow bar power Tom.
Post #621370 25th Jan 2022 5:57pm
tpeat12
Ah, that's a good shout actually. The last owner had an aftermarket tow bar fitted, which might explain why some of the conductors have been modified and taped with electrical tape.
Post #621371 25th Jan 2022 6:05pm
Sandyt
Also make sure the seal round the tailgate is clean mine got dunked up and allowed a bit of water in but most likely the washer
Post #621483 26th Jan 2022 8:12pm
