Home > Maintenance & Mods (L322) > Diff oil
Suggs
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Diff oil
Hi Guys
Can someone please confirm what diff fluid and how much i need for a 2003 4.4 petrol to change both diffs as not been done for several years.
Thanks
Post #621397 25th Jan 2022 8:59pm
Welshdragon
According to the workshop manual... 75W-90. The rear Diff take 1.2 ltr ( stated in the workshop manual - even wet refill) and the front takes 0.75 ltr.(again wet refill). If you want to keep the car along time change the Diff Olis. It is very easy to do if you have the correct pump system.
Ps....ive asked on an old thread about your gearbox judder. If it dont work.......burn it!
Post #621402 25th Jan 2022 9:42pm
Suggs
Thanks luckily the gearbox has been fine after adding some dr Tranny fluid but im about to change its oil and filter now, decided a good idea to do the diffs as well while in the garage. will order up some 75-90 Smile
Post #621403 25th Jan 2022 9:50pm
Welshdragon
Thats good to know.
Craig at camtec did my fluids a few years ago,...more like 8 years now! so i guess its time to do mine Laughing
But the gearbox is the biggy....towing my horse today a big judder at 30mph happened and worry whats round the corner.
My 322 work hard towing in Wales....the hills are steep! Ill try Dr tranny....give me some more time as a new saddle has been purchased today!
Glad yours is still going well, got to keep the early FF alive. If it dont work.......burn it!
Post #621406 25th Jan 2022 10:23pm
Suggs
worth trying the Dr Tranny as it seems to help, mine was only a very slight vibration and it stopped it instantly. Its cheap so you might as well give it a try..
Post #621432 26th Jan 2022 8:57am
