Home > In Car Electronics (L322) > Is it me or is my Bluetooth faulty?
reb78
So I was trying to pair my iPhone 7 to the Bluetooth on my new (to me) 2007 l322. So I found the car and paired using code 2121. It paired up and I thought great, that was easy, lets try a call. Being a billy no mates, I rang my answerphone. The radio stopped as the phone dialled but when it connected, there was no sound (not through the car speakers or the phone). Then the radio came back on again while the phone itself was still clearly connected to the call. I tried unpairing and repeating dialling out using the car touch screen, but nothing.
Am I doing anything obvious wrong?
Post #621525 27th Jan 2022 12:44am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Same symptoms I had, turned out to be a faulty Bluetooth module damaged by damp.
Remove your module and inspect the pins on the connector, mine had very little corrosion so I opened up the module to find the circuit board was damaged.
I purchased a 2012 module that was advertised as from a Sport so was only £50 rather than the £100 normally asked for. There is a how to in the wiki if you are not sure.
more info in my range rover https://www.fullfatrr.com/forum/topic55392-60.html
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #621530 27th Jan 2022 1:52am
reb78
Thanks David.
Oh blast. Thats a shame. Of course, now I'm looking, the modules all seem to be £120 plus! Even the RRS ones! Where did you get yours from?
Post #621536 27th Jan 2022 9:00am
bigbo
I got mine from eBay, just checked and it was £50 including postage. If I remember right I did wait a while and just got lucky.
Some are trying it on with pricing I see there is one at £236!
MG TF 2003
Post #621549 27th Jan 2022 12:18pm
TJH1985
I have a Bluetooth module removed from a 2007 here if you need one - £40?
The 2007’s don’t store the pin on iPhone afaik otherwise it’s perfect, and I believe you can get them updated if needs be. MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Previously Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #621558 27th Jan 2022 2:59pm
reb78
TJH - that would be perfect. Will you be ok to post it? I will PM my address and you can let me know the total amount and how to pay.
Thanks!
Post #621567 27th Jan 2022 4:15pm
reb78
All fixed thanks to Tom.
The Bluetooth unit was faulty. Looking at the pics of the normal problems, it had corroded pins and water damage.
Where does the water leak in from? Can it be sealed easily or is there something else (takeaway tub over the top of the unit) to stop the damage recurring with the replacement unit?
Can the old damaged units be DIY fixed?
Post #621803 29th Jan 2022 6:08pm
TJH1985
Glad it sorted it for you Thumbs Up that’s a great effort from Royal Mail I posted it quite late on yesterday!
You can probably guess that I’m insulating my garage now based on the packaging Mr. Green MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Post #621813 29th Jan 2022 6:43pm
bigbo
I tried a repair on mine, once opened it was obvious of where the water had come from. It caused corrosion on the pins of the connector and then damaged the tracks on the circuit board to the first chip. I repaired these by soldering some fine wire on to the remains of good track.
Very fiddly and required a 1mm bit on my soldering iron.
Unfortunately it still didn't work so I just gave up. I may go back to it sometime.
There is what LR call a water shedder, I got mine from Rob at Duckworths, but I've yet to fit it as I am waiting for better weather
There are loads of posts about the source of the leak worth a search.
David. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #621820 29th Jan 2022 7:34pm
