Home > Technical (L322) > Lost all Steering fluid.. replaced pump.. hose burst again..
jappie911
Netherlands
Hi,
Any tips or help would be great..: Bow down
Our LR322 4.4 V8 2002 lost all his steering fluid when my wife started the engine.
Brought the car on a trailer to a garage of a friend. (No LR dealer.)
The hose was burst.
And after replacing the hose, again. (That would have been to easy.)
So now we replaced the steering pump.
But again! Burst. Big Cry
The thing is building up a pressure somehow what is not meant to be that big.
The mechanic was now mentioning about a radiator the hose is going to.. and replace that?
What would you think?
Thanks in advance! And regards from Holland!
Post #622120 1st Feb 2022 6:06pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It sounds very much like a faulty pump, if the hoses were in good condition and designed to handle the normal pressure, the pump pressure relief valve must be stuck or blocked. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #622121 1st Feb 2022 6:14pm
jappie911
Netherlands
Thanks,
But any idea about where the relief valve is?
Or is it part of the pump ? (Which is replaced..)
Post #622128 1st Feb 2022 7:11pm
AJGalaxy2012
I would guess it's built into the pump to regulate the output pressure. BMW i3 Electric Car
Post #622131 1st Feb 2022 7:37pm
