![]() | Home > Technical (L322) > Oil level and low battery - any connection? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Have you just bought this if I’m correct?
Davidmudley Member Since: 27 Dec 2021 Location: Surrey Posts: 80 ![]() ![]() |
I’m checking it cold, and will get the dealer to resolve it if it is worth the trip there. I’m hoping there is an easier and faster resolution. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
My opinion, for what it’s worth,……
I was going to say the same thing about sucking the oil out |
Thanks for the suggestions, is this the oil extractor? https://www.toolstation.com/draper-expert-...tor/p51293 Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3347 ![]() ![]() ![]() |
A failing battery can cause all sorts of false sensor readings but you can check the level immediately after shut down when there is probably enough voltage by having the bonnet open and pressing the cruise cancel button on the steering wheel until the level shows up. It will be a bit lower than when cold or after 30mins but shouldn't be that far off. If it's OK I'd go straight for a battery replacement. If it's not OK I'd worry where the oil is going and how far it's been driven by the previous owner on low oil and I'd take it back to the dealer for a refund which you can do under the sale of good act. Also check your coolant expansion tank for oil contamination as the oil cooler seals fail on these engines - not if but when. 2012 TDV8 Vogue (L322) |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Silly question maybe, but are you checking it in the same location each time and is the ground completely level, if its at the lower end of the scale and you check on uneven ground it could throw it under the minimum. I have that problem with mine but the other end. Once full if I check it slightly nose up it reads over full! But definitely don’t drive till you know it has oil in it.
Yep ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Thanks for the thoughts & feedback. I've spoken with the dealer that I bought the car from and they've shared the preparation invoice with me that has fluids and a new battery listed on it, as a result they've asked me to bring the car in so that they can have a look over it.
So it turns out that the oil and coolant were topped up 3 weeks ago, when it was also fitted with a new battery.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Check what battery they put in. It should be an AGM battery, if it’s not then this will cause issues….. Also the Car needs updating to show it that it has had a new battery, especially if the old one was completely duff. There is nothing that can't be fixed with a hammer😜😜
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 205 ![]() ![]() ![]() |
I’d be worried of the fact of putting 1 litre of oil in depending how many miles it has done since last been changed also. If there are no leaks must be burning it. Which would need to be kept an eye on 2016 4.4 diesel |
I get low battery warnings occasionally when I have been playing about with iid etc with ignition on but engine not running,
