![]() | Home > Technical (L322) > Restricted Performance again, the engine fault light |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3328 ![]() ![]() ![]() |
Until you’ve had the codes read from it there’s so many different things it could be.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3260 ![]() ![]() ![]() |
Split inlet manifold? Mine had this and caused exactly your symptoms. Very small crack, needed a HIGH PRESSURE smoke test to find. |
PyroJames Member Since: 28 Aug 2020 Location: cambridge Posts: 6 ![]() ![]() ![]() |
I was wondering about split manifold a week or so ago and ordered new silicon ones, from a link on here. Just not go them yet, nor had the time to fit them. Perhaps that is next Saturday, or the mechanic this week. :/
You're taking about the pipes. I mean the actual manifold. The 2011 Manifold wasn't able to withstand the pressure of both turbos and has been modded up. it's c. £1600 for one manifold replacement as the injector lines have to come out. I can show you my bill (if I can find it! |
Its just been smoke tested and appears to be OK. Error codes suggesting a fault with the throttle body according to the mechanic. Mice have been in too and chewed the wiring to the EGR sensor.... |
