Home > Technical (L322) > 4.4 tdv8 car wont start
pablo
Ireland 2012 Range Rover Westminster TDV8 Fuji White
well back again.
my front LHS air bag is burst so i had to remove the fues for the air compressor to stop it overheating,so i lowered the car down all the way and when i came out this morning it wont start,i have full electrics but just a clicking sound from the engine.any help guys im starting a new job in the morning and need it badly.thanks
Post #623531 13th Feb 2022 10:59am
JCW
Obvious suggestion but have you tried replacing the fuse/s you removed to see if then starts?
Post #623532 13th Feb 2022 11:07am
pablo
i put the fuse back in before i tried to start it
Post #623533 13th Feb 2022 11:14am
Baltic Blue
Low battery causing starter solenoid to click.
Put it on charge for an hour then try again, but if it works OK, be aware it’s going to need a new starter motor soon.
Post #623534 13th Feb 2022 11:15am
pablo
this only happened me once before in the summer last year,its been fine since then,but im wondering that since its right down on the bags would that stop it starting?
Post #623539 13th Feb 2022 11:30am
