Home > Technical (L322) > Unconnected Plug in engine bay (Now with updated picture)
JamesDarby
United Kingdom 2011 Range Rover Autobiography TDV8 Buckingham Blue
Hi all,
Only had the car a couple of months and was looking around the engine and found this connected unplugged.
Its clean so I'm guessing it has been plugged in, and not left unplugged for 10 years.
Everything seems to work ok.
I've had a look around and I cant see anywhere that it should go. Anyone any ideas? You can see where it is connected to the may loom in the photo.
Its located near side front near the air filter box.
Now with Picture
I have drawn round the connector, and also where the lead connects into the loom
Thanks
James 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #623649 14th Feb 2022 9:28am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Hi James, you may want to add the picture so that we can see what plug you are talking about 2011 TDV8 Vogue SE
Post #623651 14th Feb 2022 9:48am
rjff
I think of you look under the pipe from the intercooler to the throttle body you will see a socket on the radiator/IC that it fits to.
Under 2 in the photo attached.
 Cheers
Richard
Gap IIDBT
Post #623675 14th Feb 2022 3:19pm
JamesDarby
Richard,
Many thanks, I looked all around there, saw the 2 wires on the other side and assumed that was a sensor moulded into the radiator.
Wherever it goes it didn't seem to affect anything! 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #623678 14th Feb 2022 4:00pm
rjff
James
Have to admit I haven't followed that cable yet. No doubt it does something, probably knowing Land Rover, it's connected to a random fault generator. Sad
Someone may let us know what it is for. Cheers
Richard
Gap IIDBT
Post #623680 14th Feb 2022 4:32pm
