![]() | Home > Technical (L322) > ZF6HP-26 Problems |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
That sounds as if something has failed inside the gearbox unfortunately. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3939 ![]() ![]() ![]() |
I had a very different problem with my gearbox but all I needed to do was free up and lube the linkage. It may well not fix your problem but it’s worth trying as it doesn’t cost anything. Geoff |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1399 ![]() ![]() |
After one if my drive shafts became dislodged from the diff I had similar symptoms
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 72 ![]() ![]() ![]() |
Thanks dingg1
