![]() | Home > Technical (L322) > Seat squab swap? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2263 ![]() ![]() ![]() |
Also my heating cooling is great so was going to recycle the ducts just wondered if it’s worth changing the foam topper or if it’s so thin it’s doesn’t make much difference anyway Current stable:
Yes you can put the drivers seat base in the passenger side... You will however need to remove the passengers weight switch and re install it in the new passenger seat swab sir... |
Cheers I will likely get new bases and swap Current stable:
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
I must be old. When I was growing up, the squab (British English) was the seat backrest and one sat on the cushion.
