Home > Technical (L322) > Error code B1A75-15(2F) & Fuel gauge stuck at zero
Charmer
Hi,
After making a sharp left turn my fuel gauge warning light came on.
The car has only done 50 miles since I last filled up so I now there is diesel in there!
Read the fault codes on my GAP IID Tool and the following came up and doesn't clear:
B1A75-15(2F) Fuel Sender 1 Circuit general electrical failure. Circuit short to battery or open
Has anyone else had this and has it rectified itself?
Looked online and there is mention of a TSB which involves an electrical wiring fix but this seemed to be for other LR vehicles with the same fault code.
Any help/advice gratefully received.
Post #625331 4th Mar 2022 5:04pm
Charmer
I have found a couple of threads about a similar problem but these seem to be later L322s.
Mine is a 2007 3.6TDV8 Vogue SE, does anyone know if TSB LTB00566NAS4 would work for my car?
Post #625353 4th Mar 2022 8:19pm
ajac8
The issue you will have is that even though you know it has fuel - the car may not and will soon induce the precautionary mis-fire to warn you.Then a little later it will throw the rattle and stop altogether to prevent engine damage (or so it thinks)
I know someone who had exactly that issue. turned out there was a wiring failure in the sender within the tank.
Access is easy via the rear seat squabs and a large access hole.
If I recall correctly the sender and level sensor were one unit. The tanks were saddle bagged over the rear drive tunnel.
I think there was a thread on the subject but can't find it. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #625443 5th Mar 2022 6:35pm
rjff
Charmer
Firstly, are you going to do the work yourself or "entrust"it to a garage? If DIY I may be able to help depending on what you find.
When mine suffered the same symptoms, I was lucky enough to be able to run the tank rght down and undertake the repair myself.
My fault was the pump fell over in the tank, athough it remained operational. I carried out the TSB while in there.
The TSB you refer to does show only 2010-12 FFs but it may be yours has the same in tank inline connectors that need atention.
HTH Cheers
Richard
Gap IIDBT
Post #625457 5th Mar 2022 9:25pm
Charmer
Thanks for your replies.
Went out to the car earlier and the fuel gauge is now working! Rolling Eyes
These cars are so temperamental! Censored
If it comes back I will have a go at doing the TSB fix myself. I might be back in touch!
Post #625471 5th Mar 2022 11:52pm
