Home > Maintenance & Mods (L322) > how to use clay bar?
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
hi all
i want to clay bar my range rover but not used any clay before, could someone explain how to use the clay bar and what i need to use it? Also does it scratch the paint?
Thanks
Matt
Post #70012 26th Jun 2011 1:37pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
 2002 td6 vogue, 06 supercharged facelift
Post #70014 26th Jun 2011 1:43pm
Shouldn't scratch if you keep kneading the clay to get a fresh peice. Some say you should use a clay lub. But you can just use water with a bit of car shampoo. The clay will remove all dirt stuck to the paint along with all wax and polish on the car.
Post #70017 26th Jun 2011 2:12pm
allycraven
Megs quick detailer is a good lube - definitely speeds up the process!
Post #70023 26th Jun 2011 3:28pm
