![]() | Home > Technical (L322) > ZF 5hp24 oil pan leak |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 618 ![]() ![]() ![]() |
I've been observing a slight ATF leak (weep) from the gearbox over the past several days. After excluding various posssible sources higher up, I was able to narrow it down to the oil pan. One thing I've never had leaks from has been the transmission. So what changed lately? The oil in December. I decided to try the bolts and sure enough, ALL of them were loose. Some almost finger tight |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
10nm
Thanks so much ! |
Just noticed yours is 4.4. Those settings are for Td6. John
Oops okay, then. Noted. |
Still10nm |
Great!
