Home > In Car Electronics (L405) > Cabin preconditioning with remote control? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
If you have the small fob then you will have a fuel burning heater (FBH) installed. Search FBH on here and you'll see loads of stuff about it.
12th Mar 2022 11:36am |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 816 |
Thanks Rob99 - That does help.
12th Mar 2022 8:04pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 713 |
If you don’t have the FBH (which I don’t think you do), then you can pre cool or heat the car via the app. But all it does is remote start the engine, set the temperature to what you’ve chosen in the app and leave the doors locked.
12th Mar 2022 9:10pm |
Thanks Martin - My standard spec for the car shows it as having "Cabin pre-conditioning with remote control" is that not the same as FBH.
13th Mar 2022 12:14am |
Ah, I assumed from your profile details that you had an L322. My L405 will cool but needs to be done through the climate section of the incontrol app as it needs to run the engine. The small fob I have fires up the FBH without needing an engine start. 2017 4.4 SDV8 Autobiography 2012 4.4 TDV8 Westminster - Gone, but not forgotten |
13th Mar 2022 1:09am |
Sorry for the confusion Rob. I need to update my profile, will do it now.
13th Mar 2022 7:49am |
Ahh, sorry, if you have the little remote then you have the FBH Use that for heating the car and the remote app for cooling . MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
13th Mar 2022 8:09am |
That's great - Thanks Martin |
13th Mar 2022 9:21am |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 890 |
With the FBH you'll notice some slight smoking from under the bonnet but don't be alarmed that's normal
14th Mar 2022 10:52am |
That's good to know, thanks Chalky
14th Mar 2022 9:58pm |
