![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 - who's a sucker and who's a dumper? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2768 ![]() ![]() |
Having found nothing more than a few drips from the removed hose connection after using a suction pump, I now only remove the drain plug for the turbo drain reservoir during every 2nd or 3rd oil change. Mine's hose connecter gets filled with dirt which is troublesome to clean to allow it to be disconnected so that discourages me from going back to draining from there. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3390 ![]() ![]() ![]() |
I'm a converted sucker. Draper expert is so easy to use. Regular oil changes with the specified oil and there shouldn't be any sludge to worry about. 2012 TDV8 Vogue (L322) |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 97 ![]() ![]() ![]() |
Independent annual service dumps and I do two further oil changes from the top in between using a Draper vacuum unit.
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299 ![]() ![]() ![]() |
Draper for me, although I lent mine to a mate and this has just reminded me that he hasn’t given it back yet |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
Ditto but just one home sucking oil change for me between independent specialist service ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
Do specialist Indy workshops suck or dump? 2012 TDV8 Vogue (L322) |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I know mine dumps, as he managed to strip the drain plug threads (repaired gratis).
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
I used to be a dumper, now I'm a sucker.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494 ![]() ![]() |
How long have you had the pump? Some of the 12V ones I've seen videos of seem very slow or unable to get the whole sump contents. Getting all 9.4L is encouraging however - by dumping I normally get around 8.7L. 2015 Range Rover Autobiography 4.4 SDV8 |
I've had it for around about 16 months now Gary. I've used it for two changes so far. As long as the engine oil is nice and warm the full 9.4 litres is out within a few minutes. Kev
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1880 ![]() ![]() |
Sump plug out |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 236 ![]() ![]() ![]() |
Draper pump all day long. Did mine this evening just as an interim oil change. I bought it a couple of years ago when I had a Disco 4, never looked back. |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I've got a sealey vacuum that I've owned for years. I used that to change my PAS fluid too as I vac'd the system down and kept topping up the reservoir until new fluid came through. Christian.
