![]() | Home > Maintenance & Mods (L322) > Repair or replace L322 TD6 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
The only problem with the 2nd turbo is purely cosmetic in that it blows out a cloud of smoke if not used for a while. The torque on the 4.4 is so large you will likely never need to go past 2400rpm when towing anyway. I can go months without needing the 2nd turbo….
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Thanks Jay.
Sorry, duplicate post. |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Have seen a fair few comments on Tube of U and elsewhere over the years about the robustness - or rather the lack of it - on the TD6 engine and gearbox. Have you ever seen how small that crank is, for example... Apparently, also, pulling a load (especially uphill) is not liked by the TD6 set up ESPECIALLY if a too high gear is used. But a guy who recently cleared all my three and a half years of constant faults codes popping up (where both LR and RR '''experts''' could not help - though still charged me) after ten minutes of running, said he didn't think the TD6 was that bad. So hey-ho...
Prices are only in one place - way up! £18-20k from a dealer for one in good shape. Higher than average milers come in cheaper to buy but you can easily spend the difference fixing bits that fail when the age and miles pile up. I'd avoid the 3.6 as the EGR's are an almost inevitable failure item that will take out the turbo's and possibly the engine which then lands you with a bill that makes your gearbox repair seem like a service. Infact even if the EGR's don't fail and have been replaced the turbo's can still fail + you have the weaker 6 speed ZF vs the 8spd on the 4.4. 2012 TDV8 Vogue (L322) |
Well, about to take the car to the MOT station (only 200 yards away) & no driver - at all - forward or back, high or low ranges, tried sport setting & nothing, not even a noise.
Moving on the MOT tester came round & with the suspension raised had a good look around underneath & proclaimed it sound underneath.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
You don't say where you are in the southeast but this firm has a good reputation: https://www.sussexautos.com/ John
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 698 ![]() ![]() ![]() |
Just a thought……the boxes I believe are identical to the X5 so in theory there ought to be many second hand boxes kicking about in specialist breakers that’ll come with 30 days warranty minimum……worth a try?
Thanks for the info' guys.
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
Think that may be Dartford Transmissions
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
The X5 doesn’t have a low range transfer box. I know that’s not really part of the gearbox, but it will prob mean that the L322 box is different to accommodate said item.
Thanks for all your help guys.
