Home > Technical (L322) > EGR valve oil leak 4.4 TDV8
MC-RR
Monaco 2012 Range Rover HSE 4.4 V8 Ipanema Sand
Hello,
New to the forum, please excuse any mistakes.
I would like to know if there is a gasket or seal between the EGR valve where it connects to the air plenum. I have a slight but constant oil leak .
Thank you in advance
Post #626558 20th Mar 2022 7:50pm
GraemeS
Australia
There isn't a gasket where the EGR tube attaches to the air intake - it's just a snug fit.
The oil cooler can leak from the the gasket between its 2 halves or from the gasket between the oil cooler and the EGR cooler.
Post #626562 20th Mar 2022 8:43pm
MC-RR
Thank you GraemeS,
Good to know! it just leaks enough to deposit a thin coat of oil on the EGR valve support.
Post #626566 20th Mar 2022 9:13pm
jackie-o
Netherlands
I strongly advice to have it fixed asap. In my case all the gaskets were parished causing enough oil to drip onto the EGR resulting in the valve sticking and was beyond repair
According to my indy its a real PITA job to replace the EGR as its right at the bottom of the engine and also quite expensive.
good luck! RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #626745 22nd Mar 2022 8:37pm
