Home > Maintenance & Mods (L322) > Removing plastic jacking points
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Anyone know how to remove the plastic jacking point?
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #626564 20th Mar 2022 8:51pm
There is a central pin to knock out then it vertually falls off the car sir Thumbs Up
Post #626583 20th Mar 2022 11:44pm
Caesium
Got it off but the pin is a goner!
Got to order a replacement pair of jack pads now, £20 isn't too bad for a pair. Christian.
Current Cars
2019 BMW X4
or
Post #626658 21st Mar 2022 9:15pm
Thumbs Up Thumbs Up Thumbs Up
Post #626673 22nd Mar 2022 12:11am
Bingo_123
is this a plastic pin? and does it have to be pushed in or pulled out.
Thanks
Post #630783 6th May 2022 1:23pm
You could try drilling a small dia hole up through the centre of the pin, screwing a long self tapping screw into it and pulling it out with a pair of pliers. Thumbs Up
Post #630788 6th May 2022 2:19pm
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
The Pin in the middle has to be pulled out - use a suitably strong trim tool as the pin is very tight in there but it does come out.
Once the pins out just manipulate the jack pad out of the sill. Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #630802 6th May 2022 5:45pm
Caesium
You will never lever the pin out. It has no head and sits flush with the jacking pad.
Either stick a screw in as said before or use a punch and drive it upward. Christian.
Current Cars
2019 BMW X4
or
Post #630882 7th May 2022 10:54am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Get the land rover jack out the boot and start lifting the car. Jack pad should just go straight through. Problem solved haha
Post #630899 7th May 2022 2:29pm
Bingo_123
Thanks guys, can I have the part no's please
Post #630924 7th May 2022 8:09pm
