Home > Technical (L322) > its broke down
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
its broke down
my 2011 TDV8 moved this moring about 10 feet and it has broke down outside the house the AA turned up 3 Hours later although i did tell them that it was in the middle of the road. I have the following codes come up and would really appreciate any help
P0088-22(27) FUEL RAIL/SYSTEM PRESSURE TO HIGH. GERNERAL SIGNAL FAILURE / SIGNALAMPLITUDE & GT: MAXIMUM
P0087
P0195
The other two were brought up on the AA code reader.
Many thanks in advance
Post #626701 22nd Mar 2022 11:58am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
You might want to read through my post below about a problem I had and resolved. My car is a 2010 3.6 TDV8, so there may be differences in how the fuel rail pressure is regulated.
https://www.fullfatrr.com/forum/topic49127.html
Essentially on the 3.6, there is a fuel rail pressure regulator. This releases excess fuel into the fuel feed line. But my fuel filter had never been replaced and I think wasn’t allowing the pressure to release sufficiently. I replaced the fuel filter and it has been completely fine since.
This might not be your problem, but it has to be worth a try. If it works, it’s a cheap, quick and easy solution.
Good luck. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #626787 23rd Mar 2022 9:25am
Simran0211
Brilliant I would try that but my wife (the enlightened one) had reminded me that we have a warranty on the car and after checking it out the fuel pump and most of the gubbins are covered and the AA will be collecting this morning and I still have my sanity and clean hands 🙌. Thanks for your help I will keep you updated 👍
Post #626789 23rd Mar 2022 9:39am
Simran0211
Just a quick update Steve the garage had the car for the weekend but found no fault which cost me half a tank of fuel and £210. Couple of weeks later I experienced the same fault but this time the AA patrol man had said that he had come across this problem once before and said it’s the auxiliary fuel pump. He gave it a bash it sprung into life I got it home changed the pump and BOB’s your auntie it’s been fine since. Thanks for your advice Thumbs Up
Post #630272 1st May 2022 11:52am
TDV8 Paul
Good news, thanks for updating 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #630326 1st May 2022 9:30pm
