![]() | Home > Maintenance & Mods (L322) > Seat foam replacement cost and question |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 959 ![]() ![]() |
Had this a few times when replacing seat base foams - if you cut the top ‘dome’ section off a 2 litre plastic fizzy drink bottle, and temporarily insert it into the ducting so it holds it in shape, you then gently heat the foam with a hot air gun & it will re-shape & set in place |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2288 ![]() ![]() ![]() |
Nice I bit the bullet as the topper was collapsed too but I will do as you say and keep as a spare in case I do the otherside Current stable:
