Home > Technical (L322) > New noise from the engine… high pressure fuel pump |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
Its been a few days since I finally swapped the fuel filter for a new one, and have given the car ‘the beans’ a few times again still with no re-occurrence of the noise.
14th May 2022 8:58pm |
Frustratingly the squeal has returned. It’s been a pleasure basking in the refined quietness that is the cabin of an l322… however I bask no more.
28th May 2022 10:23pm |
I was chatting to a local garage about this noise… which frustratingly wasn’t there at the time…
2nd Jun 2022 7:58am |
Cheers Phoenix.
2nd Jun 2022 9:04am |
If you can read the values for the volume control valve, that would give an indication of supply issues - it could also be a restriction on the outlet of the pump or return to tank line...
2nd Jun 2022 11:37am |
With this conversation still fresh in my mind the family and I headed off to the beach. The car was quiet and we were happy enjoying the peaceful drive when I decided to overtake a slower car. A slight blip of the throttle and the car eased past as always… except I was a little more heavy footed than usual and she nipped to about 2,800 revs and the noise was back. All the way to the beach.
2nd Jun 2022 8:43pm |
Mate, chuck a cheap filter in it, cut the top off the old one and have a look at the filter material, until you do that - everything else is just a guess. |
2nd Jun 2022 8:47pm |
So, the noise came back!
26th Jun 2022 8:46pm |
From your last observations, it sounds like a restricted return line. |
26th Jun 2022 9:12pm |
Umiar Member Since: 21 Jun 2022 Location: Cracow Posts: 11 |
Here is mine, in my opinion it has something to do with fuel pump because sound depends on throttle position, not rpm.
4th Jul 2022 7:34am |
Hi Umair,
8th Jul 2022 10:10pm |
I want to tackle this now following a frustrating journey to and from the train station…
8th Jul 2022 10:13pm |
Yeap, mine appears at low rpm when accelerating and disappears at constant speed. No success yet, but now I’m thinking about visco fan… will let you know. |
10th Jul 2022 10:16am |
Zelfor Member Since: 18 Apr 2024 Location: Boston Posts: 3 |
Ffrr-lover / Umair … any updates on this. My rover has the same issue.
18th Apr 2024 2:37pm |
