Home > Technical (L322) > yet more problems
BrianC
yet more problems
my air con has stopped working i had it regassed 1 year ago and it appears to be working as it leaves a puddle under the car as normal (beside the gearbox) but no cold air. might it be blocked?
also when going round a roundabout the traction control is kicking in as if there is something loose underneath
but i had it checked last week and i replaced the 2 bottom arms+balljoints and the problem is still here
Rolling Eyes
Post #68289 12th Jun 2011 6:41pm
RANGEROVER
England 2003 Range Rover SE Td6 Zambezi Silver
possible reasons...
Air Con - slow leak / low refrigerant if still operating but not actually getting cold, hence water dripping off evaporator but evap not getting cold enough to notice.
You need someone to evacuate system - recharge and check for leaks and use gauges to check correct operation, they must not just top it up.
Traction control
- check tyre pressures
- check for damaged wheel speed sensor at a guess. If you worked on the front check where the wire goes into the hub you may be able to repair if damaged it may be a pain if you have to remove it.
Hopefully others may have some definate answers...
Post #68324 12th Jun 2011 9:19pm
i get the feeling that the FFRR looses aircon gas very quickly especially if the a/c isnt used much...i brought mine in august last year and the a/c was ok then but nothing there in april this year..i've re-gassed mine and all seems ok now...
Post #68352 13th Jun 2011 8:33am
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
My compressors leaking in 3 places so having new one fitted on Thursday. Thought I just needed a re gas but that didn't work. On mine th air was colder when the aircon was off??? Hopefully all good in few days tho.
Cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #68425 13th Jun 2011 7:13pm
