Home > Technical (L322) > Asthmatic L322
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Asthmatic L322
Recently I replaced my pulleys, alternator, water pump, and a few other bits.
To do this I had to remove my coolant tank and air filters. I did it over the course of several very cold days.
One of those cold mornings I went to start work on the car and opened the bonnet to find the foam inserts at the end of the bonnet and in the door hinge areas were torn out as they were stuck with ice. Not a major issue as I’ll simply stick them back at some point (still haven’t gotten to that job).
Since completing the work I’ve noticed that i can hear the noise of the air intake on the drivers side. With the windows shut its barely noticeable, however under acceleration it is more pronounced. Not enough to cause me concern… I’ve noticed it now so can’t ignore it.
My assumption was that the suction noise was simply travelling up the gap under the bonnet and the lack of foam inserts allowed the noise into the cabin.
While this is certainly true, I realised today that you can hear the suction of the intake from outside the car, which increases as you rev the engine (obviously). And that realisation included that it was far noisier than it should be for this car.
Is this one of those “they all do that sir” noises I simply never noticed until those foam inserts were missing? Or is there a problem?
I’ve checked and the 4” pipe to the engine is securely fastened, and the Airbox itself is properly seated in the wing hole… in that the box itself fits inside the wing rubber surround and no gaps.
I also popped the pipe off the Airbox and put my hand over the hole and it pulls tight into my hand and i hear no new noises elsewhere. This suggests that there is no leak further down the intake.
I also notice that the noise from the disconnected pipe sounds the same as the noise outside so that noise is either normal but travelling outside the car, or that is the source of the abnormal noise.
Any suggestions as to why my car sounds like Darth Vader taking a long deep breath? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #630218 30th Apr 2022 7:08pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Mine does the same thing, drivers side only. It’s quite loud when the window is down and I’m manoeuvring slowly, especially up a curb or something similar. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #630219 30th Apr 2022 7:15pm
Ffrr-lover
Further to this i had a new noise today…
I pulled into a reasonably steep slope off a main road to quickly let the lil’un out of the car to urgently water the plants. When we tried to reverse back up the slope, and timing a gap in the main road, i would hear a flutter from the engine. It sounds like a turbo dump noise… but a few in quick succession.
I’m not sure if linked to the air noise i am hearing at all? I am aware that the turbos feed each other so suspect the Turbo Bypass Valve is probably to blame somehow? I have an MY12 and believe it would have the newer vacuum actuator (?) which shouldn’t stick?
It has been suggested that this may be caused by the vacuum hoses, and i may need to replace those?
Any ideas? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631654 14th May 2022 9:21pm
mjdronfield
Mine does that in reverse, as you power on and release, I have a step up into my garage and just squeezing throttle to get up there does it.
Think a few have the same thing.
No noise forwards though….
For some reason…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #631658 14th May 2022 9:41pm
Ffrr-lover
Cheers mjdronfield,
Thats reassuring at least. I am still trying to track down a power drop between the turbos (at around 2400rpm) and hoped this might have given some insight…
Oh well, lets keep on looking Sad Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631682 15th May 2022 9:01am
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Are all the jubilee clips nice and tight on the turbo hose’s or have any split? 2016 4.4 diesel
Post #631692 15th May 2022 10:54am
Ffrr-lover
Funnily enough I was out this morning double checking everything. All hoses appear ok as best I can see without stripping everything down, and all jubilee clips tightened some more - none felt particularly loose.
I did, however, spot something…
Crap picture, but circled is a hose that was not connected! The absolute Censored who last touched the car forgot to connect it back up again! Whistle
While this has not made a difference to the noise, I’ll take her out later for a spin to see if there’s any other changes… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631694 15th May 2022 11:04am
JayGee
Strangely enough when I was doing an oil change on mine I found a similar hose on the other side nr the air box. It's got a 180 deg bend at the top and is not connected to anything - does it go in the airbox and is it a breather hose? 2012 TDV8 Vogue (L322)
Post #631702 15th May 2022 11:56am
Ffrr-lover
The photo I took was the driver side and the hose appears to be a vacuum hose.
The passenger side has no such connector on the air box.
The pipe I think you are referring to is clipped to other pipes and is snug to the 4” intake pipe that goes down in front of the engine. I recall that not being connected when I started working in the engine bay, so believe it doesn’t actually connect to anything, nor can I see how it would get to the Airbox as the stiff bends don’t allow it.
I think you are right that it’s a breather hose Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631718 15th May 2022 1:28pm
JayGee
Further research has ID'd it as the front diff breather hose. 2012 TDV8 Vogue (L322)
Post #631719 15th May 2022 1:29pm
Ffrr-lover
Good find Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631721 15th May 2022 1:34pm
Tdtj
As I found out yesterday as I was fitting mine back together googled the part number What did we do before Google Very Happy 2016 4.4 diesel
Post #631727 15th May 2022 3:11pm
