Home > Technical (L322) > Dipping wing mirror (s) when reversing
Tiprat
Good morning everyone, I've been trying to adjust the reversing dipped mirror function with no joy.
At present if reverse is selected and the mirror adjust button is in the passenger side, the passenger side mirror dips and looks at the floor Question If I try to adjust it whilst in reverse it does nothing. If I slide the mirror selector button to the drivers side, whilst still in reverse the passenger side raises back up to the normal driving position. If I take the RR out of reverse I can alter both wing mirrors depending where the selector button is, so the functions are clearly working, I just can't alter the reverse function.
Is it only adjustable via IDD? Or should it be adjusted just by selecting reverse and altering it? Like you see on the utube videos. Or more likely am I missing something simple..... Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #630350 2nd May 2022 9:13am
mjdronfield
You should be able to adjust it when you are in reverse and it’s dipped… then it will go there next time……
Not really helped I know….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #630396 2nd May 2022 12:53pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Interstingly I have just reversed mine & i'm unable to adjust once the mirror is atuo dipped in reverse. Yet both are fully adjustable & work fine once removed from reverse. Whistle
Post #630405 2nd May 2022 3:25pm
mjdronfield
Maybe the later cars are different, but I’m sure the TD6 I had was adjustable… like my 2011 car….
Looks like my old man memory may be iffy then 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #630406 2nd May 2022 3:55pm
Merchy
My 2006 Td6 - cannot be adjusted whilst dipped for reversing, otherwise all functions working ok.
Post #630420 2nd May 2022 6:31pm
