Home > Technical (L322) > 3.6 tdv8 not starting |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 201 |
When I was messing with my injectors and had the leak off pipes off and on, it took ages to fire up, then suddenly it went 2007 TDV8 Vogue SE
4th May 2022 12:58pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Fuel line needs priming, don't know the exact procedure on this engine but that's what the problem probably is... |
4th May 2022 1:33pm |
Nathan v8 Member Since: 04 Dec 2019 Location: South Wales Posts: 15 |
is it normal with the return (leak off pipes) off the injectors im getting a good stream of fuel with the ignition on from the return pipes?? |
4th May 2022 3:16pm |
