Home > My Range Rover > My FFRR 2012 TDV8 Vogue
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
Hi y'all,
I just bought my FullFat and I'm so happy with it
It's a child like happiness !
I've already faced a dead battery and a gasket leak at the oil filter (the usual)
I've added a secondary battery in the right side trunk pocket (Luxury LR kit = excellent and easy)
and I've switched all easy accesible lamps to led. I've also replaced a front door rear trim (the large losange one at the driver seat).
So far so good
I have a question though how do you call that thin window frame trim (i pointed it with a red arrow) ? So a would be able to order or find a replacement one (it is rusty...)
Cheers
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #630875 7th May 2022 10:14am
Merchy
I think the correct term is 'Door frame surround trim' found this set on the net - below
https://www.ebay.co.uk/itm/133804646129?fi...SwG4xgYyNx
Must be new ones somewhere for sale, but probably expensive ! Hope this helps Thumbs Up
Post #630910 7th May 2022 6:21pm
ergobyte
Thanks
But I'm looking for the outer trim, not the frame.
like that part here :
I found this on the WIKI, but still don't know what to call it ... "it needs some intelligence to undestand you may not have enough"
Post #630912 7th May 2022 6:47pm
ergobyte
Thanks for the help,
as I'm not a native speaker its hard to master the technical linguo... Laughing
I found this
https://www.ebay.co.uk/itm/264857299513?ha...SwR9BfVhCu
I rthink it's the right one (and the right door)
Cheers
Post #630916 7th May 2022 7:33pm
ergobyte
Now that I bought it,
I'll have to figure out how to change it Rolling with laughter Rolling with laughter Rolling with laughter !
Cheers "it needs some intelligence to undestand you may not have enough"
Post #630920 7th May 2022 7:47pm
