![]() | Home > Maintenance & Mods (L322) > Fluid levels check before L322 drive to Italy |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
I'd check the levels again after another run and then decide. Too much oil is not a good thing for an engine... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 834 ![]() ![]() ![]() |
Thanks Dr Rob....... I'm going to take it back to the garage in the morning.
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 322 ![]() ![]() ![]() |
I’d say you need to unscrew the expansion bottle bleed screw (black plastic screw on top of the bottle), and then undo the expansion tank cap and allow the coolant to settle in the bottle. Looking at it I’d guess it will end up between the cold fill lines.
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
just top up the coolant when the engine is cold, it should be in the middle of ''cold fill range'' |
Thanks maric995 and fanders - I managed to get it sorted.
