![]() | Home > Maintenance & Mods (L322) > TD6 Brakes. At loose end |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
HDC just keeps the car within a certain speed and stops it running away. It can brake each wheel individually so it good when off roading on a steep slippy decent, as it will keep the car slow and straight. You holding the brake a bit will brake all 4 wheels, which may make it slide or slip sideways…. It’s pretty impressive. On the later cars you can change the set speed a bit, but not on the early cars I don’t think.
Have you progressed any further?
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Hey!
Ok..
Nice one. Got there in the end.
