Home > Maintenance & Mods (L322) > External trim color
External trim color
Hi Guys
Today i have taken the pax wing mirror off the car and i have started to strip it down and sand as i had corrosion under the powder coat that looked awful. I've got primer and i got a can of black satin. Would you say that all the exterior trims (doors and windows) wing mirror base's are satin or gloss black? I use autoglym bumper care stuff on the black so don't want them to look different or stupid.
Post #68686 15th Jun 2011 7:49pm
daveo
hi, they are satin black...take some photos of you work. Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #68709 15th Jun 2011 9:48pm
Cheers. Will do. Not sure if its a common fault or I've just been unlucky, but both mirror bases look bloody awful.
Post #68712 15th Jun 2011 10:00pm
All finished, well one side anyway. Peice of Censored job. Used the powerful uk video on YouTube on how to remove the mirror. Once off removed the finishing cover from under the mirror and masked off the mirror. Unfortunatly I couldn't fully separate the base from the mirror but it helped when masking and sanding. I used a screwdriver to get the corroded powder coat off then a Stanley knife to help get the powder coat off past where the corrosion ended. Once this was done I used some sandpaper to remove the corrosion from the aluminium to get it back to bright alloy. The sandpaper also helped to blend the powdercoat into the aluminium. Once this was done gave it 2 coats of primer allowing plenty of time to dry between coats. Then 3 coats of satin black. Leave to dry then refit. Easy peazy. While doing the mirror I resprayed the bonet vent as per joe90's post. Will upload a few photos later when I get time.
Post #68795 16th Jun 2011 3:57pm
looking forward to the pics ROB.. Thumbs Up
Post #68799 16th Jun 2011 4:03pm
Here are a few pics.
Corrosion on drivers side. (forgot to take before pics of the pax side) drivers side worse than pax.
Sealed up the hole overnight to stop and rain getting in
2nd coat of primer after being rubbed down
1st coat of black
2nd coat of black
Finished and fitted. You can still see a few pit marks from the corrosion but much better than before
Doesnt look to bad when done
Sprayed bonnet vent while waiting for wingmirror to dry
Ready to fit
Finished article
Post #68855 16th Jun 2011 6:53pm
Googsy
Top Job Thumbs Up what colour did you use for bonnet vent?
Post #68857 16th Jun 2011 6:58pm
Its Rover stone silver. Used the same as Joe90.
Post #68859 16th Jun 2011 7:04pm
